Altair RISE
Nominate Yourself Now!
Problem with creating TCL scripts in HyperMesh
User: "juliuus_"
Altair Community Member
Updated by juliuus_
Hello!
I´m new to scripting in HyperMesh and want to learn a bit more about it.
My problem is: When I want to create a new TCL/TK script from "Create New TCL/TK Script" in the HyperMesh scripting toolbar, nothing happens. I can see a starting window (I guess it´s from HyperMath) and then receive the following error message:
"Unable to create proper channel. HyperMath may not work as desired."
Do you have any idea how to fix this problem and start scripting in HyperMesh?
Thank you!
Greetings from Germany!
1 - 3 of 31
    User: "tinh"
    Updated by tinh
    Hi,
    I got the same error.
    You can use a text editor (like Notepad++) to write your scripts, and run it from hypermesh menu File>Run>Tcl Script
    Or even use hypermesh command window to write and run scripts:
    User: "juliuus_"
    OP
    Updated by juliuus_
    ok, thank you tinh. Are there any other options too solve this problem? have you asked the customer support yet?
    User: "tinh"
    Updated by tinh
    Hi,
    I don't know how to solve this problem. Because I didn't use that toolbar, never use it so I don't ask customer support.
