🎉Community Raffle - Win $25
Join and Win
view orientations in thick shell elements in lsdyna interface
User: "Learner_22225"
Altair Community Member
Updated by Learner_22225
Hi,
I am using Hyperworks with ls-dyna interface.
Hyperworks sussessfully able to import the .k file with *part and *element_tshell_composite .
I am not able to view the orientations using 'Ply layer and direction'.
Please let me know the other viewing methods to view the thickshell orientation definitions available in Hyperworks.
1 - 3 of 31
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Hello,
    In order to visualize your model as plies, its needs to be modeled using a ply based modeling schema. I don't believe that is how ls-dyna behaves, I believe they use zone based. So you can absorb to ply based for visualization.
    I would take some time to look at this youtube series on composite modeling in hypermesh
    thanks
    OP
    Hi, In LS-dyna interface, composite defined using thick shells look like this. Probably I should be using Realize instead of Absorb, if there is a single click process.
    Should I first export my dyna model into Optistruct and if the OS model is exported good, I should apply Realize step to view plies. Should this be the procedure to follow?
    Altair Employee
    You can refer to this video and the attached example file
    https://www.youtube.com/watch?v=4AFA8INa20w&list=PLGNemB0NFb0BcNU7CMkFcgrGRBVGMrwPj&index=3
