LICENSE problem
I have installed hyperworks but have problems with license.
I have installed hw on local machine (windows) but don't know what i do wrong.
My altair_lic.dat is empty, so I don't know how to use the 'create a USER_SERVER license file' procedure.
I tried the 'set up environment variable' procedure, but didn't work.
I tried also with flex license manager and didn't work.
What do i do wrong?
When I try to open i get this:
altair license manager: license error
Cannot connect to license server system.
the license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the port or hostname in the license file has been changed.
feature: globalgridworksEU
server name: 192...
license path 7788@asus; 1055@asus;C:/Altair/hw10.0/security/altair_lic.dat
flexnet licensing error:-15,10. System error: 10061 'Winsock: connection refused'
I don't know why i get two license path. 1055 was the port number used when i had ansys installed. But now ansys isn't installed anymore.
What port do i have to choose? do i have to do something to remove the old ansys path? How do i have to modify the altair_lic.dat file to get it work?
If ttfLicenseFile.txt in the license number, why do i need the altair_lic.dat file?
The guide says that you have to modify it into:
SERVER 101.953.23.21 807d4212 7788
USE_SERVER
In my case what do i have to write? I have to write my ip address insead of 101.953.23.21 but what instead of 807d4212 and 7788?
Thanks
If you are working on Vista, perhaps you have to upgrade your FLEXNet version, it must be al least 11.4 (see http://ol.cadfamily.com/Hyperworks10/help/hw/hw.htm?licensing_and_installation_release_notes.htm)
Replace lmutil, lmgrd and lmtools .exe file with the ones you find at producer website:
/>http://www.globes.com/support/fnp_utilities_download.htm'
hi
