Optistruct Optimization creates 1000 plies
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello everybody,
I'm not entirely new to FEA analysis but I'm struggling with Optistruct at the moment.
I have a Formula Student Monocoque which I am trying to optimize to work with unidirectional carbon. I'm trying to create an optimum lay-up that's as light a possible while being as stiff aswell.
I followed the guide 'tutorial composite optimization with optistruct 11.0 on the example of a formula student monocoque' to the letter but somehow the Optistruct Optimization creates almost 1300 plies... Which is is impossible to manually adjust the zones...
Could somebody have a clue what's going on here? Maybe I'm doing something wrong in the OptiStruct settings? I should have only 4 plies per original ply on default...
Thank you in advance! I attached the model file.
Regards
Alexander
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi @nodroz
    Which version of HyperWorks are you using?
    Can you share version details and also updates installed on your machine?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hey Prakash, thanks for the fast reply!
    I'm running Hyperworks 2017.2.2 on Windows 10. I'm also running the Optistruct 2017.2.2 hotfix update.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi,
    There is a problem with the update and it because of that OptiStruct is creating more than expected number of plies.
    Developers are fixing this and should be cleared soon.
    Can you run the size optimization and check if that provides any good results with the same 1000+ with a TMANUF or PLYMAN?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Thank your for the reply, I'll have a look into that!
    Meanwhile I installed version 2017.2 (so removed the 2017.2.2 hotfix) and everything is working fine!
Welcome!
Welcome!
