🎉Community Raffle - Win $25
Join and Win
I want to register a proc and want to call back it when ever i use *translatemark nodes (Shift + f4 ) to move nodes
User: "Hypermesh User"
Altair Community Member
Updated by Hypermesh User
I used the below command to call the proc ::minanglecorrection3d, but it's not calling the proc once I have done with *translate nodes (Shift + f4 ) to move nodes
catch {hm_framework registerproc ::minanglecorrection3d after_*translatemark nodes 1 1 0.1}
Please help me to register a proc and need to call it whenever I use *translatemark nodes (Shift + f4 ) to move nodes
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Hi,
    hm_framework just accepts some special callback events (user profile changed, menu redraw,..)
    to add callback to *commands you need to use:
    ::hwt::AddCallback *translatemark ::minanglecorrection3d "after"
    your callback proc must have an argument as placeholder for HM passing *translatemark... into
    example
    proc ::minanglecorrection3d {star_command} {
      puts "Command was performed: $star_command"
      .... do your work here
    OP
    Hi Tinh,
        Thanks for your help Its work great, Is there any option to unregister the proc by passing command.
    User: "tinh"
    Accepted Answer
    Updated by tinh
    Yes,
    this command will unregister the callback:
    ::hwt::RemoveCallback *translatemark ::minanglecorrection3d
    OP
     Copy that Many thanks, Mr. Tinh.
    User: "Ajay Prabhakaran"
    Hello Mr. Tinh,
    Can we register a proc during the client change. The proc should be executed during the client change from HM to HV or vice versa.
