surface graph plotting issue
Yun_20312User: "Yun_20312"
Altair Community Member
Updated by Yun_20312
I have RCS data of model that I had, and I tried to visualize RCS of the data that I had.
the RCS data was calcurated in multiple phi and theta, so it is 3 - dimensional data.
To visualize it, I tried to use Surface graph plotting method in altair feko, but the result is not correct.
as I attached the image, this one has too many 0.0 or values around -5.0.
but the real data doesn't have that much values.
What is the problem? is it due to feko software's internal visualization problem?
1 - 11 of 111
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Yun,
    Can you share the data file so that I can test?
    Thanks,
    Zeina
    OP
    Hi Yun,
    Thanks,
    Zeina
    I attach my postfeko pfs file. if you need original cfx file, let me know and I will attach it
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    Thank you for sharing the .pfs.
    I will need the .ffe along with the .pfs session. Without it the main data is missing.
    OP
    I tried to upload ffe mile but the system says it is unsupported file format. are there any way to upload data?
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    You can zip it then upload the zipped archive.
    OP
    Hi Yun,
    Thanks,
    Zeina
    here is the zip file containing ffe file
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Yun,
    I don't see any issue with the plots. Here are some points I have randomly picked from a surface plot of the data. You'll see that all three values were correctly plotted.
    Note that the RCS values in the .ffe file are in m^2 and not in dBsm.
    If you have specific points where you have observed discrepancies between the data and the plot. Please share their info.
    OP
    Hi Yun,
    I cheked the .dat file I exported with m^2 surface graph, and confirmed there is no issue in RCS value in .dat file. RCS values are all the same with .ffe file.
    but what I thouht wrong was surface graph of dB, not m^2.
    could you check RCS value from dB version of surface graph? if you could, export graph to .dat file and see RCS values. mine is:
    as you see, there are pointless -4.0 values, which is totally wrong.
    this one is showing results converted from m^2 to dBsm.
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Yun,
    Interestingly, I do not have the same values as you when exporting to .dat:
    What version/subversion are you using?
    OP
    Hi Yun,
    I'm using Altair FEKO 2019.3.3, which is quite old version.
    so far I thouhgt even though I use old version there is no issue, but seems there are bug / software error when converting m^2 value to dBsm.
    ZeinaUser: "Zeina"
    Altair Employee
    Updated by Zeina
    Indeed, your version is very old. I strongly recommend you update. A lot of enhancements and feature additions have been added since.
    Best Regards,
    Zeina
