🎉Community Raffle - Win $25
Join and Win
How to properly set the G parameter in GRAV bulk data entry?
User: "mansin"
Altair Community Member
Updated by mansin
Hi,
I have been confused by the parameter G in GRAV bulk data entry. I think this parameter is the acceleration of gravity. If I use the unit system of “kg, N, mm, MPa”, Should the parameter G be set to 9810 ? I found that If I set  G to 9810, the displacement of the structure in the case of gravity  is too large.
1 - 2 of 21
