Setting a Default Value
Hey guys,
I'm writing a script, where I can set a value (e.g. for the Young's Modulus) for a material property.
My problem is that I would like to have a default value in the window, like 210000 MPa, which I can take and proceed or change it if it doesn't suit my material. Is it somehow possible to set such a default value?
Kind regards and thanks in advance
Simon
Attached you can find the part of my script and a screenshot of the window I'm talking about:
*startnotehistorystate {Modified E of material}
set youngs_modulus [hm_getfloat 'Youngs Modulus (Steel)=' 'Enter Youngs Modulus:']
*setvalue mats id=1 STATUS=1 1= $youngs_modulus
*endnotehistorystate {Modified E of material}
1 - 2 of
21
Thank you @vipin! that helped me a lot.
Hi @Bachelor22
add default value after the string
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
set youngs_modulus [hm_getfloat 'Youngs Modulus (Steel)=' 'Enter Youngs Modulus:' 210000]
