Problem Optimization
Hello everybody,
I'm trying to do a composite optimization following the tutorial that described a monocoque FSAE optimization; I made the first step (free size optimization) but when I try to edit the ply shape for manufacturability and I try to start the second optimization, I have an error:
A fatal error has been detected during input processing:
*** See next message about line 31 from file:
C:/Users/Salvatore/Desktop/Altair ottimizzazione manuale/Ottimizzazione/Ottimizzazione con DOF
'DESOBJ(MIN)=6'
*** ERROR # 1041 *** in the input data:
Card DESOBJ conflicting with previous DESOBJ, MINMAX, or MAXMIN data.
I noticed that after the first optimization are created automatically other objectives, other otpimization control, response and constrains; maybe they could be the cause of this error?
Thanks
Hi,
For linear analysis honeycomb modelling as in core for composite analysis is usually modelled with SOLID elements with equivalent isotropic properties. The ply’s/laminae which are the face sheets on either side of the core are modelled with Shell elements (PCOMP/PCOMPG/PCOMPP) with orthotropic material property.
Regards
Rahul R
Hi Salvinho,
I think there are two objective functions. Can you please check this?
