TCl begginer
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello I have started working with tcl recently
I want to write programme for creating a node equivalence in two parts
in large assemblies it become combursome to select all components and check for equivalence
i would like to know to write this programme and what are general guide lines for this
Thank you
1 - 6 of 61
    User: "tinh"
    Altair Community Member
    Updated by tinh
    A bit confused. Why don't you just Shift+F3 > equivalence all of them , instead a script?
    :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
    Altair Employee
    OP
    hello thank you for reply tinh
    I read that anasa there is command that will directly joins two independently meshed model by just changing the localised mesh so (only by selecting the elements in area and defining seam line )
    I want to develope something like that
    User: "tinh"
    Updated by tinh
    I don't understand
    please tell namely what you want to do
    Altair Employee
    OP
    suppose I have 100s of components meshed by different meshes
    then I want to create a tcl so that on only selecting two surfaces it should do node equivalence or trimming or extending the surface as per user instructions
    and also remesh the localized area
    and take input from user like tolerance and all
    and also edit the mesh around area and re mesh it to required size and create a uniform mesh do all the things done by node align and all
    so now based on previous examples available on the forum I have developed some of programmes for trimmimg and for node equivalance
    the problem in node equivalence programme is its node showing the preview of node equivalance
    and I also want to create a button on the user page I have followed tutorial available but unable to create a button
    Thank you
    attaching files have check
    User: "tinh"
    Updated by tinh
    Hi,
    must have '$' sign in front of 'distance'
    *equivalence components 1 distance 0 0 0
    Altair Employee
    OP
    Thank you
