TCl begginer
hello I have started working with tcl recently
I want to write programme for creating a node equivalence in two parts
in large assemblies it become combursome to select all components and check for equivalence
i would like to know to write this programme and what are general guide lines for this
Thank you
Answers
A bit confused. Why don't you just Shift+F3 > equivalence all of them , instead a script?
/emoticons/default_rolleyes.gif' title=':rolleyes:' />
0 -
hello thank you for reply tinh
I read that anasa there is command that will directly joins two independently meshed model by just changing the localised mesh so (only by selecting the elements in area and defining seam line )
I want to develope something like that
0 -
I don't understand
please tell namely what you want to do
0 -
suppose I have 100s of components meshed by different meshes
then I want to create a tcl so that on only selecting two surfaces it should do node equivalence or trimming or extending the surface as per user instructions
and also remesh the localized area
and take input from user like tolerance and all
and also edit the mesh around area and re mesh it to required size and create a uniform mesh do all the things done by node align and all
so now based on previous examples available on the forum I have developed some of programmes for trimmimg and for node equivalance
the problem in node equivalence programme is its node showing the preview of node equivalance
and I also want to create a button on the user page I have followed tutorial available but unable to create a button
Thank you
attaching files have check
0 -
Hi,
must have '$' sign in front of 'distance'
*equivalence components 1 distance 0 0 0
0 -
Thank you
0
