🎉Community Raffle - Win $25
Join and Win
Meshing failed when using mold
User: "Nancy Jewel Mcdonie"
Altair Community Member
Updated by Nancy Jewel Mcdonie
Hi all experts,
I got a problem: When I run without a mold, there is no error. But when I use mold, it said that: Meshing has failed...
So the problem maybe come from the mold. I want to ask for your help...
Thank you all.
1 - 1 of 11
    User: "Saurabh_Bhamania"
    Altair Employee
    Updated by Saurabh_Bhamania
    Hi Nancy,
    The issue is with the CAD, if you are using default meshing strategy then you need to make sure that the part and the mold components have proper contacts created at the interface. You can try running with smaller mesh size.
    Or try the alternative meshing strategy from Files > Preferences > Inspire Cast Analysis > Meshing strategy. And switch it to Alternative meshing if using 2023 or later builds.
    This helps in providing better interface contacts or try using voxel meshing for solids if alternative meshing fails.
    Please check and let us know if this helps or if the issue persists please create a service now ticket so that our experts can help you with your issues.
    Thanks.
