Rigids with cylindrical system
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
hi everyone,
I've create a fixed axial displacement in the indipendent node of a rigid (whose displacement is assigned to a cylindrical system). The only problem is that the dependent nodes (these too assigned to the cylindrical system before creating the rigid) moves in a different direction, as if their assignement to the cylindrical system wasn't valid anymore. Does it mean that rigid are not compatible with cylindrical system?
Below I've attached a pictrure that show the issue.<?xml version="1.0" encoding="UTF-8"?>rigid_problem.png
thanks,
Luke31
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2016
    Hi Luke31,
    Is the independent node assigned to local system?
    Can you share the model file?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    yes, before defining the rigids, I've assigne both the indipendent node and the dependent nodes to a cylindrical system located in the system collector.
    Here I've attached the model.
    Thanks,
    Luke31
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2016
    about this model, I've another question about a different issue. Can I ask there o should I create another post?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2016
    You can create another post.
    I am working on your issue, will update to you soon...
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2016
    Dear Prakash,
    have you got any news about my issue?
    Best regards,
    Luke31
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Luke31,
    Not yet, but I will update to you soon regarding your question.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Luke31,
    I updated the system and nodes,
    I don't see the behavior as you shown in an image in from one of your posts.
Welcome!
Welcome!
