Rigids with cylindrical system
hi everyone,
I've create a fixed axial displacement in the indipendent node of a rigid (whose displacement is assigned to a cylindrical system). The only problem is that the dependent nodes (these too assigned to the cylindrical system before creating the rigid) moves in a different direction, as if their assignement to the cylindrical system wasn't valid anymore. Does it mean that rigid are not compatible with cylindrical system?
Below I've attached a pictrure that show the issue.<?xml version="1.0" encoding="UTF-8"?>
thanks,
Luke31
