Altair RISE
Nominate Yourself Now!
How to reverse force direction?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
I'm applying a force in the Z-axis direction but it's coming up the wrong way, is there a way to change the direction? (down rather than up?)
Thanks in advance
1 - 4 of 41
    Altair Employee
    OP
    Just change the sign : if the current value is positif, change to negatif value.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    If it is Hypermesh Radioss user profile.Then reversing load direction is issue.Even though if you give - sign it wont reverse load (Display)
    Hypercrash would work fine for such instance.
    Altair Employee
    OP
    Hi,
    I'm using Optistruct and working on a flat 2D model. I'm trying to change the direction of the force from underneath to above. I can't see the sign you speak of.
    Thanks
    In Magnitude enter -200.000
