Capture Contour Plots
Santosh G
Santosh G Altair Community Member
edited October 2020 in Community Q&A
I want to capture contour plots in jpeg format For multiple steps in one go. I have used the attached script, it is giving me contour plots for all the increments.
is it possible to take contour plots in each step for only last increment (last Frame) with modification in attached script?
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    For changing the increment, if i recall correctly, you need to use
    ResultCtrlHandle SetCurrentSimulation #increment.
    You can also obtain the number of simulations/increment with GetNumberOfSimulations
    Similarly i belive we have GetNumberOfSubcases
    And SetCurrentSubcase #sub_id
    Then just loop through your subcases using a for loop.
Welcome!
Welcome!
