Capture Contour Plots
Santosh G
New Altair Community Member
I want to capture contour plots in jpeg format For multiple steps in one go. I have used the attached script, it is giving me contour plots for all the increments.
is it possible to take contour plots in each step for only last increment (last Frame) with modification in attached script?
For changing the increment, if i recall correctly, you need to use
ResultCtrlHandle SetCurrentSimulation #increment.
You can also obtain the number of simulations/increment with GetNumberOfSimulations
Similarly i belive we have GetNumberOfSubcases
And SetCurrentSubcase #sub_id
Then just loop through your subcases using a for loop.
