🎉Community Raffle - Win $25
Join and Win
Compute magnet and rotor losses in a 3D simulation
User: "Ciro Alosa_22608"
New Altair Community Member
Updated by Ciro Alosa_22608
Hi everyone,
I would to compute the magnet losses on a SPM machine.
The magnets are axially divided into several blocks in order to reduce the eddy currents circulation.
The rotor yoke is also axially laminated with several axial slices.
I found the application note of the IPM motor in order to create the 3D model with several blocks.
I have some questions:
  1. Can i extrude different face regions with different lengths?
  2. Do I have to define an airgap face region between two magnet axial slices in order to compute the insulation between the magnets and reduce the eddy currents circulation?
  3. Do I have to define an airgap face region also for the rotor yoke axial slices and assign them on the faces between two slices?
  4. If I want to extrude a face region multiple times across one direction, how can I do? Do i have to set a offset value on every extrusion or do I have to assign the face regions to the new faces on the new volumes created and then extrude them?
In addition, I tried to model this motor once, by starting from a 3D CAD, with airgap face regions between the magnets slices and the rotor yoke slices, but i get this message:
"The coupling with neighbouring volume regions of faces:
363 340 317 294 271 248 225 202 179 156 133
of face region ROTOR_AIR is forbidden.
107 102 97 92 87 82 77 72 67 62 57 53 49 45 41 37 33 29 25 21
of face region MAG_AIR is forbidden."
I removed the airgap face regions but I get this message:
"The group of volume regions:
- STATOR
is multiply connected (have hole(s)).
There can be a problem called connexity problem if a coil forms
an interlacing with the group of volume regions.
If you have a connexity problem, you must create a cut of
magnetic circuit which cuts the group
of volume regions.
It has not been possible to automatically set formulations
to regions.
You must assign yourself the formulations, choosing a
formulation model different from "Automatic formulations", as
follows:
- menu: [Application] [Edit current application]
- in the dialog box, click on the "Formulation model" tab,
- choose a formulation model different from "Automatic,
formulation"
Thank you for your kindness.
1 - 17 of 171
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Hello Ciro;
    To build your Flux project please have a look on the 3D tutorial available from the supervisor, there is a step by step pdf.
    The rotor laminations are not needed to be displayed, you can use a dedicated magnetic laminated non conducting region, we use it to take into account the lamination and its impact on the material characteristics.
    It is forbiden in 3D to put airgap face region between two solid conductors, it is allowd only to use insulating face region.
    When you have connexity problem, you have to create the magnetic cut loop. It can be done automatically if you go on [physics] -- [magnetic cut loop].
    Once you created your project, i can have a look on it to check if it well defined or you still miss some settings.
    Best regards
    OP
    Hi Farid,
    thanks for the reply.
    Do I need to define an insulating region between two solid conductors in order to simulate the effect of reduced eddy current circulation?
    The rotor yoke is laminated with a mild steel therefore I can't define the region as a laminated region but I have to define a 3D model with axial lamination also for the rotor yoke.
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    You are welcome!
    Yes, in order to model the segmentation, you have to use insulating face region.
    If the rotor is made by two blocks of lamination, you can display the airgap geometrically between this two blocks and still using laminated volume regions. If this airgap is too small, then you are allowed to use airgap face magnetic region. When this face is located between two magnetic non conducting region, it is allowed.
    Regards
    OP
    You are welcome!
    Regards
    Thank you very much for your patience.
    What about this error: "It has not been possible to automatically set formulations
    to regions.
    follows:
    formulation""?
    Regards
    OP
    Thank you, and what about the message:
    to regions.
    follows:
    formulation"
    What does it mean?
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Can you check if all the face regions are used ? otherwise you should simply delete them.
    If you still have this error message after rebuilding the Flux project with all the previous discussed changes, you can upload your Flux project here, so we can check.
    Regards
    OP
    Regards
    Thank you, after doing your modifications the problem was gone.
    The last question I have is: can I build a periodic 3D starting from a complete model, using the Flux 3D modeler?
    OP
    Sorry to bother you, but when I mesh the domain I get the following message:
    "Advancing front mesh on volume 49 failed. Check the face mesh."
    What is the problem?
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Which version of Flux are you using ?
    OP
    Flux 2021
    OP
    I ran a check mesh and I didn't get any errors. But when I finished to mesh the domain I got the error I wrote before.
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Are you using extrusive mesh ?
    If it is the case, you have to refine the mesh along the extrusion.
    Regards
    OP
    Regards
    I followed the application note fron your advice.
    How can I know if I am using extrusive mesh?
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Well, in the application note we are not using extrusive mesh.
    Can you please upload your project so i can check what is going wrong on it ?
    Regards
    OP
    Yes. Can I upload privately?
    User: "fzidat"
    Altair Employee
    Accepted Answer
    Updated by fzidat
    If you want to keep it private, please use the regular support instead of using the forum.
    OP
    Thank you for your support.
