🎉Community Raffle - Win $25
Join and Win
MotionView templates
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I try to do the 'MV-1051 - Understanding Sequential Simulation' tutorial with MotionView 2017.
It is the second tutorial where i get an error on creating a template.
This is what i write in the 'Write text to solver input deck:
<Constraint_Joint
id='5000'
type='FIXED'
i_marker_id='{the_model.m_slider_track.idstring}'
j_marker_id='{the_model.m_1.idstring}'
The first marker is different from the tutorial because i type a different name. If i use the function bar and evaluate it then i can see that he found the right markers. Where is the problem in my template?
This is the error message if i check the model:
1 Error:   Syntax error in expression:
              <Constraint_Joint
              Templex error evaluating text under The Model-Fixed Joint Defn..
Finished Checking Model
Errors were detected in the model.
If i try to make the next template in the tutorial i get the same problem.
