Altair RISE
Nominate Yourself Now!
How to create a node in the center by selecting one circular curve?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
In hypermesh, we can create a node in the center by selecting three node on a circular curve. How can we script this?
Roy
1 - 6 of 61
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Open command.tcl file you will see the script
    Altair Employee
    OP
    Hi tinh,
    I know your meaning. When using GUI, the center node can be created by selecting three nodes. How can we create the center node directly by only selecting one circular line not three nodes by using script?
    Roy
    User: "Beta"
    New Altair Community Member
    Updated by Beta
    Hi Roy,
    You may already know this panel
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8b2233a3eb575810117aaa1b463409d9.png
    use it generate nodes on the curve and use generated nodes to create center nodes. do necessary steps then you could find out commands in command.tcl
    User: "tinh"
    Updated by tinh
    Hi tinh,
    Roy
    F8>create node at 'circle center'
    User: "Pandurang"
    Updated by Pandurang
    *createmarkpanel lines 1 'Select Line to get center';
    *createbestcirclecenternode lines 1 0 1 0;
    *clearmark lines 1
    User: "PSiedlaczek"
    Updated by PSiedlaczek
    # to loop trough many crucial lines at one selection :
    *createmarkpanel lines 1 'Select all lines to put temp-node at center';
    set line_sh [ hm_getmark lines 1 ];
    set ile_li [ llength $line_sh ]
    if { ! [ Null line_list ] } {
      for {set i 0} {$i <$ile_li} {incr i} {
        set liID [ lindex $line_sh $i ] ;
        eval *createmark lines 1 $liID
        *clearmark lines 1
    puts "Enter: tcl is harder than you think"
