Sliding surface is not a revolution surface
Hi,
I have designed a 3D stepper motor with Flux. If I try to simulate it, Flux gives me the following error:
'The sliding surface of the mechanical set ROTOR
Concerned face(s) : 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 101 103 105 107 109 111 113 115 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 1
Impossible to solve problem'
Hi Ciro,
I am very interesting in your model. In fact I am statrting to investigate how simulate a stepper motor in Flux but I am not so skilled in Flux. It is possibel to have your model? Also a dummy or not deatailed model could be very usefull!!
Thank you very much
Having similar issues on dual rotors and single coreless axial flux motor. Pls give a tips on how you solved the problem
Hi,
Can you send us your Flux project.
Thanks.
