Altair RISE
Nominate Yourself Now!
Sliding surface is not a revolution surface
User: "Ciro Alosa_22608"
New Altair Community Member
Updated by unknown
Hi,
I have designed a 3D stepper motor with Flux. If I try to simulate it, Flux gives me the following error:
'The sliding surface of the mechanical set ROTOR
Concerned face(s) : 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 101 103 105 107 109 111 113 115 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 1
Impossible to solve problem'
1 - 9 of 91
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Can you send us your Flux project.
    Thanks.
    OP
    Updated by unknown
    How can I send you the project?
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    You delete the mesh and use zip format.
    best regards.
    OP
    Updated by unknown
    Thanks, I solved the problem.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    You are welcome.
    User: "Saml"
    Updated by Saml
    Hi Ciro,
    I am very interesting in your model. In fact I am statrting to investigate how simulate a stepper motor in Flux but I am not so skilled in Flux. It is possibel to have your model? Also a dummy or not deatailed model could be very usefull!!
    Thank you very much
    User: "Mihai"
    Updated by Mihai
    Hi, Ciro,
    Do you remember how you solved the problem?  as I have the same one ..
    User: "Mihai"
    Updated by Mihai
    Hi Ciro,
    Do you remember the way you solved the issue? as I have the same one..
    User: "Ishaqlad89"
    Updated by Ishaqlad89
    Having similar issues on dual rotors and single coreless axial flux motor. Pls give a tips on how you solved the problem
