Strain and Stress Results on hypermesh not visible
Altair Forum User
Altair Forum User
Altair Employee
edited May 2021 in Community Q&A
Hello,
I did a calculation on Optistruct via Hypermesh demanding the output results for the displacement, stress and strain but on Hyperview I can only see the results for the displacement.
Can someone please tell me if I have forgotten to enter a data necessary to view the strain and stress on hyperview?
In the NLSTAT, I activated Displacement, Strain and Stress for the OUTPUT and did the same for the GLOBAL_OUTPUT_REQUEST card.
I await your response,
Please and thank you
KBE
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi KBE,
    Can you please share the global output request details?
    Make sure you have requested for stress-strain results in H3D format.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi KBE,
     Hello Prakash,
    Due to confidentiality, I can not share the file with you. Can you please explain where i can define H3D for the stress and strain?
    Thank you
    - Kaushely
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi KBE,
    Hi again
    I found where to change the format, but it still doesn't work. Is there anything else that I have to define along with the format? I didn't see that you requested just the global_output_request details. Please see the attached images.
    Thank you
    -Kaushely
  • tinh
    tinh Altair Community Member
    edited March 2018
    Hi,
    What kind of element types do you analysis for stress/strain?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    element types as whether they are solids or shells?
    both elements are solids and they are both cylindrical components. I am trying to encase one component with the other.
  • tinh
    edited March 2018
    Could you try activate GPSTRESS and GPSTRAIN also and run analysis again?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    yeah ok, hold on. Ill do that and send you the results shortly
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
     do I have to deactivate the normal stress and strain? and set the format to H3D for GPSTRESS and GPSYRAIN?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Tinh,
    I still can not visualize the stress and strain results. Maybe it's a setting in hyperview that I have to change? Please see attached image.
    thank you
    -Kaushely
  • tinh
    edited March 2018
    You don't have to deactivate other, but please set gpstress format to h3d
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    ok, trying again
  • tinh
    edited March 2018
    Tinh,
    thank you
    -Kaushely
    Maybe something's wrong in process.
    Did you select correctly *.h3d file?
    What kind of analysis are you doing?
    Did solver raise some errors or warning?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    I opened the .nl.h3d file and I didn't get any errors but there are some warnings. See below:
     *** WARNING # 6328
     Loadcase 1 contains a GPSTRESS output request but NLOUT incremental
     output isn't available for that result type. Results will be output
     for the last increment exclusively.
     *** WARNING # 6328
     Loadcase 1 contains a GPSTRAIN output request but NLOUT incremental
    When I open the .h3d file, i can't see any movement.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    ok, i opened the .h3d file and found the result options but everything is 0. Unlike the .nl.h3d file, i can not see any displacement or deformation.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Tinh,
    it's working, it was a very stupid mistake. I opened the .h3d file and set the animation mode to 'set transient animation mode' and it's working.
    Thank you so much.
    - Kaushely
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi @KBE If you have NLMON in your setup, .h3d will not provide results while the job is running and I think this is why you didn't see any results
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi Prakash,
    yeah I noticed that later on.. thank you
    - KBE
  • Michele Romano
    Michele Romano Altair Community Member
    edited May 2021
    Hello everyone, I got the same problem with thermal analysis.
    I can see results only for temperature but not for thermal gradients.
    Can you please tell how to solve it ?
    Regards
    Michele
Welcome!
Welcome!
