I'm trying to mesh a part that is, by my standards, very simple. It is designed in Solidworks and imported to HyperMesh in .STEP format. I have been trying to use tetramesh with trias/tetras and a 0.100 element size, which produces errors 'shell elem region incomplete' followed by '1 surfs failed and saved'. The resulting mesh is a 2D surface instead of a 3D solid. All I would like is assistance in making the mesh solid and eliminating these errors.
Also for some reason I can't upload any files - not .hm, not .step, not .iges. So I have attached a picture of the design if that helps at all
