🎉Community Raffle - Win $25
Join and Win
Beam self-contact
User: "ivanIEV"
Altair Community Member
Updated by ivanIEV
Hallo everybody,
I am trying to simulate spring(modelled via beam3N elements). During simulation, spring should have a lot of contact points with itself and it has in a fact, but the cross-section of beam elements isn't accounted. In another words there are contacts between points of helix(middle line). Does anybody know this problem? I am using contact type 11.
Regards,
Ivan
1 - 5 of 51
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    Can you share a picture of the problem you are facing with, please?
    User: "ivanIEV"
    OP
    Updated by ivanIEV
    Pictures are in attachment
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi Ivan,
    contact detection is defined by Igap parameter. In your case you could use Igap=1000 constant gap equal to Gapmin=beam diameter.
    But this could be problematic if the second image shows initial configuration with a lot of initial penetrations. Those could be handled by Inacti=5 or 6.
    If the second image shows the deformed configuration with deep penetrations, then increase the contact stiffness by increasing parameters:
    -Gapmin
    - Stfac
    User: "ivanIEV"
    OP
    Updated by ivanIEV
    Hi Ivan,
    yes, it is:
    I found solution, it is simple and stupid:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />  Length of my beam elements was smaller than diameter,  so solver understood Gapmin not correct from the start...
    Thank you for support!
    Hi,
    I am glad you have solved the issue. Care to share the method used to manage it?
