Internal Error - PH02246melem.ff
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
solving a hypermesh model in HyperXtrude leads to an internal error. The only additional information is 'PH02246melem.ff'.
It happens in the second time iteration, log says:
***** Time Step: 2 of 35, Step Size = 0.25 sec *****
***** Nonlinear Iteration Number : 9 of 25 *****
TEMPERATURE CALCULATION STEP
VELOCITY CALCULATION STEP
**** SOLVER ERROR STOP ****
Any idea, where to look, to get that working again?
Thanks,
J.
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2009
    I had a similar error <ph00635assm-dri>
    I found that that there were zero diagonals in the matrix...
    I was able to find the most likely cause... five 3D mesh elemnts got deleted while i was fixing the boundary conditions... So, may be u need to re-examine ur mesh.. thats my guess (I m a newbie too!!)
    Zero diagonals resulted, probably, because element connectivity in the matrix could not be established due to the missing elements.. agian a wild guess!!
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2010
    Check if Container and Billet elements are connected. If they are, then detach them. Make sure you have correct deformation type for the tooling.
Welcome!
Welcome!
