Imprint Bead from Geometry
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
i am looking for a quick way to adapt an existing mesh (green) to a new geometry (yellow). In the picture the mesh is coincidient to the geometry, except the bead geomtry stands out. In the mesh there is no bead, and i want to try force the mesh into the beads shape without manual meshing tasks.
Has anyone some experience with that? Please help!
<?xml version="1.0" encoding="UTF-8"?>post-3178-0-88193400-1378726310_thumb.pn
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2013
    Hi,
    you can try to use the following:
    Menu: Morphing->Map to geometry->map to surfaces
    Try it with domains or nodes, normal to geometry.
    Hopefully it works,
    Regards
    Mario
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Morphing is good method. But if the element quality is important, you have to remesh locally. For surface mesh, it's so easy. It takes me about 5' to do that correctly.
  • Altair Forum User
    Altair Forum User
    Altair Employee
Welcome!
Welcome!
