🎉Community Raffle - Win $25
Join and Win
Extracting data from FEKO to polar plot in MATLAB
User: "AGirlHasNoName"
Altair Community Member
Updated by AGirlHasNoName
I have simulated an array of dipole antennas in FEKO and extracted the polar plot data of the far field radiation pattern in the form of a .dat file. However, when I am plotting the same graph using MATLAB using the extracted data, I am getting a completely different result. I am attaching the images of the plots obtained using FEKO and MATLAB and also the data file extracted from FEKO. How can the polar plots be obtained using MATLAB? Please suggest.
P.S. I have used the following MATLAB command after importing the .dat files (containing data from the FEKO polar plot for radiation pattern): polar(Phideg,FarField)
1 - 5 of 51
    User: "Mel"
    Altair Employee
    Updated by Mel
    Hi Barman
    Since there is nothing wrong in Feko, and you have the ASCII data file, I would suggest you contact Matlab support.
    User: "oussama1"
    Updated by oussama1
    I have faced this kind of problem before. take the data from feko without using dB scale. then, plot them in matlab.  I have always faced problems with dB plot in matlab.  this is a matlab problem.
    OP
    I have actually found the solution to it. After importing the data file to MATLAB we need to write the command: polarpattern(Phideg,FarField1dBV).
    This is giving me the same results.
    User: "Mel"
    Altair Employee
    Updated by Mel
    Thanks for letting everybody know!
    User: "Spencer Sellers_21091"
    Updated by unknown
    Matlab polarpolt requires the angle data be in radians. polarplot(deg2rad(Phideg), FarField1dBV) will give you the correct result in Matlab.
