Dear All,
My analysis is completed well but the solver is showing Running 1 job and the h3d file is not generating.
Thanks
RAM
Seems like the run has been terminated due to maximum energy error.
Can you share the .out and engine file.
Dear George,
I had sent the out file in your drop box.Kindly check and let me know the error.Also in that out file the error is 99.9% through out the simulation.
Please send the engine file also (_0001.rad)
Clear the penetrations in the model and try running the analysis. if there are penetrations in the interface, energy error may show up.
I have got the results .Thanks for the support.
Ram
