Importing load from Excel
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi everyone am working in Hypermesh(Aerospace) profile, i want to import load from excel which has nodal coordinates(or Element ID) and XYZ component forces .
How to do this??
Thanks. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
1 - 10 of 101
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    @Prakash He want to IMPORT load defined in Excel file, not INTERPOLATE as you suggest. Maybe the resultant is not so different, but that's not the same.
    @mano112aprmw Do you know something about TCL programming? I think you can export Excel into CSV format et write a TCL script to read & apply to your model.
    Altair Employee
    OP
    @Q.Nguyen-Dai My mistake.
    @mano112aprmw
    One way is to have forces/moments in the form of .dat file which you can directly import in OptiStruct profile (.dat format is shown in image)
    Here is a script to Create force on nodes using box selection. The Force and the box coordinates are defined in an external csv-file and force magnitude is divided to number of nodes that fall under this box.
    Altair Employee
    OP
    You can download the script from Script Exchange https://connect.altair.com/CP/kb-search.html
    User: "tinh"
    Updated by tinh
    Hi,
    I have an ideal.
    Thinking that excel is also very powerful to process data,
    you can use its formulas to generate a *.fem file then import to hypermesh
    example with node coordinates and force components,
    I will generate GRID data, CONM2 (mass elems) at those grids, and FORCE on them,
    after import to your model,
    you can easily to use panel tool>equivalence to stick CONM2 to your nodes, then delete CONM2:
    <?xml version="1.0" encoding="UTF-8"?>Capture.thumb.PNG.3818dc4e0fd677bc534b6e68ed2f4ca2.PNG
    sample excel:
    Yeah, for 'small' & 'average' analysis, that's ok.
    But for 'big' (>1.E+6 nodes), maybe you hit Excel limitation :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "tinh"
    Updated by tinh
    :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' /> it's high probability with him - students often like to do big one
    Altair Employee
    OP
    @mano112aprmw
    @Prakash Pagadala, how can I import the .dat file?
    Altair Employee
    OP
    Hi @Johannes
    You can import .dat file in OptiStruct/Nastran profile in HyperMesh.
    Goto Import>>Solver Deck>> Change file type to All file formats>> Select the .dat file>> Import.
    Altair Employee
    OP
    Hi,
    I have an ideal.
    sample excel:
    Hi @tinh,
    How would this Excel to FEM model be adjusted if you want to use it to create only pressures at x_node, y_node, z_node instead of Force components?
    Cheers
    User: "tinh"
    Updated by tinh
    Hi,
    Pressures must be define on elements, not at x, y, z coordinates.
    Please describe your problem in detail
