🎉Community Raffle - Win $25
Join and Win
how to get assem name of a component
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi all,
can anyone pls help me in finding assembly name of a component
thanks in advance
regards,
JAMIE
1 - 5 of 51
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hello Jamie,
    You can try using the below method, there could be a better way to do too.
    #set the component ID to search:
    set n_compID 18
    set lst_assemblyID [hm_entitylist assembly id]
    foreach assemblyID $lst_assemblyID {
        set lst_componentID [hm_getvalue assembly id=$assemblyID dataname=components];
        if { [lsearch $lst_componentID $n_compID] != -1 } {
            puts 'Component $n_compID is in Assembly [hm_getvalue assembly id=$assemblyID dataname=name]';
    Altair Employee
    OP
    Hi Jamie,
    You can also try with:
    *createmark assems 1 'by comp' compid
    hm_getmark assems 1
    User: "tinh"
    Updated by tinh
    :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> George, it's the shortest way. I thought it would return parent and grandparent... assems of a comp
    Altair Employee
    OP
    Hi Jamie,
    hm_getmark assems 1
     hi George,
    this is returning the parent assembly name.
    but i need to return the sub asssembly
    Altair Employee
    OP
    Hi Jamie,
    You can try with hm_assemlist ~ which will return the hierarchical structure of assemblies.
