/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> George, it's the shortest way. I thought it would return parent and grandparent... assems of a comp
Hello Jamie,
You can try using the below method, there could be a better way to do too.
#set the component ID to search:
set n_compID 18
set lst_assemblyID [hm_entitylist assembly id]
foreach assemblyID $lst_assemblyID {
set lst_componentID [hm_getvalue assembly id=$assemblyID dataname=components];
if { [lsearch $lst_componentID $n_compID] != -1 } {
puts 'Component $n_compID is in Assembly [hm_getvalue assembly id=$assemblyID dataname=name]';
