Abaqus Card Editing
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Does anyone know how to write a script that will go into a property or a material card and update it? For example, if I want to card edit my material 'STEEL' and enter in the density, Poisson's ratio, etc, how could I put that in a macro? Thanks.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2010
    Hi
    Try the below code for a simple model and check it will update all materials density to 111
    //Get material names
    set MatList [hm_entitylist mats name]
    // Updates all materials density to value 111
    foreach MatName $MatList {
    *createmark mats 1 $MatName
    *attributeupdatedoublemark materials 1 4 1 1 0 111.00
    if you want to update only for steel then use the below code
    #Get material names
    #Updates steel material density to value 9200
    if {$MatName == 'Steel'} {
    *attributeupdatedoublemark materials 1 4 1 1 0 9200
    Check the code....
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2010
    more generally spoken:
    1) clear your command.cmf file
    2) perform the actions you want to do automated by hand in HM GUI
    3) check the command.cmf file and replace the () and , in the *xxxxx commands to get the same commands via tcl;
    and finally: fill your parameters per tcl ...
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2010
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2015
    How can I import the card edit entities to an excel sheet?
    For Example)
         Young's modulus to a column in excel
  • tinh
    tinh Altair Community Member
    For Example)
    Hi
    open Utility tab and looking for 'material table'
    open material table and select File>export>csv
    you then can edit material properties in excel file
Welcome!
Welcome!
