I want to check time step mesh information for explicit analysis. In 'check elements - time' after entering the desired time step and clicking 'check elems' I get the error 'No attributes defined in current template'. How to fix this?
HI,
Which HyperMesh version are you using?. Ensure material and property are assigned to the components.
If possible please share the model file so that we can review the file.
