Altair RISE
Nominate Yourself Now!
In TCL How to skip command if it dosen't have any entity to select.
User: "shubham Dhokare_21832"
Altair Community Member
Updated by shubham Dhokare_21832
Hello everyone,
I have created a sample script attached below. I want a modification in it. For example if I want to move knuckle solid in knuckle comps, but If I didn't receive the knuckle geometry from my client and I run the script. If this solid is not there to select then this command file stops and execute an error. So I want to skip the particular commands if there is no solid for selection.
*createentity comps includeid=0 name="KNUCKLE"
*createmarkpanel solids 1 "Select Knuckle Geometry";
*movemark solids 1 "KNUCKLE"
*createmark components 3 "KNUCKLE"
*createstringarray 2 "elements_off" "geometry_on"
*hideentitybymark 3 1 2
*clearmark solids 1
*createentity comps includeid=0 name="DISC"
so in the createmarkpanel if I didn't have any geometry to select .... and without selecting any geometry if I proceed it should skip the commands till createenity comps includeid=0
So if solution available please guide
Thanks & Regards,
Shubham Dhokare
1 - 10 of 101
    User: "Brett Ramsey_20633"
    New Altair Community Member
    Updated by unknown
    if {llegnth [hm_getmark solid 1] == 0}{
    continue
    } elseif {llegnth [hm_getmark solid 1] != 0}{
    *clearmark solids 1
    This should do the trick. Hope it helps
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    There are probably a few different ways to do this.  The most straight forward to me is to just do an if statement to check the length of the list like this
    if {[llength [hm_getmark solids 1]] > 0} {
    <your other commands>
    Hope that helps.
    OP
    continue
    *clearmark solids 1
    Thanks for reply Brett, Your syntax work fine for me .... But I want to make some modification in it. Like I have 16 solid and for each solid I have to write this code ... Is it possible to use loop function Or can you suggest any other idea to reduce this syntax length
    OP
    Hope that helps.
    Thank you Ben , your syntax work for me. I have 16 solid and Now I just want to decrease the syntax length ... So if you have any suggestions please do reply Thanks again
    Altair Employee
    Actually if that is the case you can probably just use a foreach loop instead of the if statement.
    foreach solidID [hm_getmark solid 1] {
    *clearmark solids 1
    So if the list is empty it won't do any of the commands which addresses your first question but if the list is longer it will do it for each one.
    User: "Hypermesh User"
    Accepted Answer
    Updated by Hypermesh User
    Hi Shubham,
      hope this will help you..
    #create the list of part name to be created.
    #APpend your 16 solid name in the list.
    set Listpartname { KNUCKLE DISC }
    foreach {partname} $Listpartname {
    *createmarkpanel solids 1 "Select $partname Geometry";
    *createentity comps includeid=0 name="$partname"
    *movemark solids 1 "$partname"
    *createmark components 3 "$partname"
    *clearmark solids 1
    Regards,
    Manoj
    OP
    Thanks for the reply .
    It worked perfectly and saved a lot time
    Welcome..
    OP
    How to calculate volume and area for SOLID using tcl ? I tried hm_getmass but it supports only for elements and comps. And in comps it only supports to elements.
    Hope this helps you..<br /><img src="https://us.v-cdn.net/6038102/uploads/attachments/7a037eb7db459914cfd5f6a4e29619d9/Community-Pasted-Attachment-1659965549105.png" /><br /><img src="https://us.v-cdn.net/6038102/uploads/attachments/7a037eb7db459914cfd5f6a4e29619d9/Community-Pasted-Attachment-1659965746315.png" /><br /><br /><br />
