Zero Inlet Condition
User: "Rajkamal B"
Altair Community Member
Updated by Rajkamal B
Hi,
I am a Acusolve user and I cannot simulate flow starting from 0 lpm to 10 lpm.
Is it possible to get the Nodal Initial Condition for this kind of simulation.
For Example: Let lets consider a nozzle. If i want to simulate a flow with increasing flow rate of 5lpm to 10 lpm. i need to generate a steady state flow with 5lp as inlet velocity and get the NIC file and feed it to the transient model as instructed in ACU-t:3101 Transient Conjugate Heat Transfer is a Mixing Elbow tutorial.
What i should do if i need to simulate for 0lpm to 10lpm flow rate.
Thank you in advance,
Regards,
Rajkamal
