Can I Have Properties Automatically Applied?
After creating a mesh I have to apply either a pshell, psolid or prod to all of the components. As of now we manually create and assign all properties. I would like to have a script to automatically apply these properties.
I cant find a way for HM to identify the component type and apply the correct property.
Is this possible? Can anyone help me?
I am getting familiar with TCL. I have tried multiple ideas/commands and none of them I can get to identify the element type. Once I get that under control the application of the properties I believe I have under control.
The principle is rather simple: do as manual whatever you want to define propeties et assign to your components.
Have a look at the file 'command.tcl' ==> Play with TCL script /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
in nastran or optistruct profile, create 1 pshell, 1 psolid, 1 pbeam. assign them to all comps.
then open tab Utility> click Auto property
Of course, it's possible
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> But should learn TCL firstly
