Altair RISE
Nominate Yourself Now!
Inserting a unique header row into an already parsed data in DPS to be exported for SQL as CSV
User: "Henry_21370"
Altair Community Member
Updated by Henry_21370
Hello,
I would like to know the best approach as to how I may insert a header and trailer into parsed data to be imported into SQL.
I need to add the following items in the header (to be exported as a pipe-delimited in CSV file):
    1) the captured file name of the input file (metadata information?)
    2) the total number of rows of parsed data
    3) the total amount in $ from a summed column
I currently have 12 columns of parsed data, so I understand that the header will not be aligned with the data columns.
The trailer should just contain an 'End of File' row for SQL to recognize that no further rows of data is in the pipe-delimited CSV file.
I checked out the following previous discussion thread for a similar procedure, but had no headway into how to make it work properly, unless it can truly be accomplished through Monarch Classic application using the Summary tab. Not sure how....
https://community.datawatch.com/thread/3695
Thank you for your feedback.
Henry
