coreOUT Problem
awe901
awe901 Altair Community Member
edited October 2020 in Community Q&A
I'm attempting to run my sim with the '-coreOUT' command in run options. It will go through the preprocessing within Hypermesh, but then it will not actually launch the Optistruct window as it normally does. My PC can't handle the memory requirements, so I must run it as an Out-of-Core sim. Any solutions?
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    -core out  >> don't forget the space between core and out.
    Have in mind that out-of-core is much slower than the core in.
    Maybe reviwning your model size/refinement.
  • awe901
    edited August 2020
    Ahhh. I haven't been using the space. Thank you so much.
  • awe901
    edited August 2020
    Actually, let me ask you this:
    -ncpu 4 -core out -fixlen 16000
    and the solver won't launch. But it will launch with just -core out. Any idea for why this happens?
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    not sure.
    avoid using names and folders with spaces and special characters.
    F:/Aaron/Documents/Hsiao Thesis/Hypermesh/2X2 RUN A.fem
    try
    -nproc 4 -core out -fixlen 16000
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    by the way, make sure you're running in a local disk and not using network drives.
  • FaroukM
    FaroukM Altair Community Member
    edited August 2020
    Try to use an HPC plateform if you have a heavy FE model ...
Welcome!
Welcome!
