Hi,
I want to do modal analysis of engine & fixture assembly. I'm gonna consider engine as a rigid point mass, so i will create a node representing engine and i will assign inertia (Mass, Moment of inertia) to that. Subsequently i will connect the point mass to fixture mounts through rigids. I don'no how to assign inertia values to node. Any help regarding this will be of great help to me...
Thanks!!!!
After creating mass element (CONM2), card edit the element as below,
Now, click on the CONT option to input the inertia values:
