Problem with Crasurv
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I'm trying to understand LAW 25 with CRASURV formulation. So I perform a single element test to see how it works. As far as I can see from the Radioss Reference Guide, it should be possible to use different values of plastic work for each material direction by setting the Flag Iflawp=1. So I do that, but there was no effect. The global criteria (Wpmax) was still the dominating one and the local one (Wpmaxt1,Wpmaxt2,.....) has no effect. That means, the Element is ruptured when the global criterion is reached. If I deactivated the global criterion the local one also has also no effect, which means that the element is not ruptured.
What do I wrong?
best regards
1 - 10 of 101
    Altair Employee
    OP
    Hi,
    My Problem is still exisitng. Have anybody an Idea which seettings are important to use CRASURV?
    best regards
    Altair Employee
    OP
    Hi MrEtker,
    do you see a similar behaviour with LAW25 TsaiWu?
    according to the reference guide, if Sigma11 is greater than Sigma yield in tension then ruptures takes the local values.
    maybe you have to increase the load so that stress from tension and compression in major direction is greater than SigmaYt and SIgmaYc.
    Altair Employee
    OP
    Hi,
    Yes I see the similar behaviour. The stress value is greater than the Yield stress but there is no rupture of the element. After the Yield stress is reached, i modeled plasticity hardening which occurs
    until a mximum stress is reached. Afterwards the Element should be ruptured at Wpmaxt1=110, but it didn't do it. I attached the stress/strain curve and the material card to check.
    best regards
    <?xml version="1.0" encoding="UTF-8"?>post-36561-0-58378700-1426065424_thumb.j
    <?xml version="1.0" encoding="UTF-8"?>post-36561-0-22912500-1426065433_thumb.j
    Altair Employee
    OP
    Hi All,
    I am checking this with experts. I will get back to you ASAP.
    Altair Employee
    OP
    Hi Prakash,
    Is there any progress regarding my problem?
    best regards
    Altair Employee
    OP
    Hi,
    Meanwhile can you please let me know what is the version of HyperWorks you are using?
    Altair Employee
    OP
    Hi,
    I'm using Hypermesh version 13.0.110 with Radioss Block 12.
    Altair Employee
    OP
    Hi,
    can you run the same analysis on 13.0 solver?
    I shared a video with you. The animation file after running in 13.0.
    Altair Employee
    OP
    Hi,
    I have tried with 13.0 solver. Now it's working. Thank you.
    best regards
    Altair Employee
    OP
    Hi Etker,
    Thanks for the update.
