Leafspring builder log error
Hello,
I would like to create a costum leafspring, i have entered the .csv file to give the leafspring builder the overall shape of the leafspring. I have also entered the coordinates for the mounting points. Other than that i left the default settings like the steal properties for example.
The problem lies when i try to build the spring, I dont have any error in the Cheking phase but once I click ok, I have a message that there is an error in the log. I tried to understand the erros but i dident manage to understand much. I added the .txt file of the error log.
Also when I check the model there are no error or warnings.
If someone could help me it would be great.
Thank you !
Best regards,
Angus Duff.
Hi Adam,
Thank you for your response.
No MDL files are created and I think the log is the entire thing, it's a log application error. I left a capture of the log as displayed in the leafspring builder.
Best regards,
Angus.
Hi Adam,
Best regards,
Angus.
Hi Angus,
Can you attach the CSV file so others can give it a try?
If you don't want to release it to the Community you could always create a Support Case instead.
Thanks,
Adam Reid
Hi,
Yes i can share my .csv file, its not a convetionnal leaf spring geometry, that's maybe why, but i know someone who managed to create a leaf spring similar to mine, so i don't really know.
I can't import a .csv file on this forum so I imported the default Excel file type if you don't mind.
I will try and creat a support case as don't have any idea why is not working.
Best regards,
Hi,
Best regards,
Hi Angus,
I'm not sure if a support case was created or not, but I can import that leaf spring geometry as follows:
It looks like a single leaf with nonconventional geometry. Are you able to save the current model as a Leaf Property File or LPF? (Menu >> File >> Save As)
Hope this helps!
Adam Reid
Hi Angus,
Does the leaf spring MDL definition get created? Or is no MDL created?
Is that the entire LOG file or just a snippet?
Thanks,
Adam Reid
