- Contact output for linear analysis(Available from OptiStruct version 2019.1)
- Contact output, such as Contact Force, Traction and Deformation, are available for linear analysis via the CNTF I/O Entry.
Linear static analysis using tie contact
I am running a linear static analysis..where i given a Tie contact between two solid bodies..in the output results the stress results are different on master and slave surface..why?
Usually we will get same stress on master and slave interface in linear static analysis, is it right?
and can we see tie contact force in linear static analysis?
1 - 1 of
11
