🎉Community Raffle - Win $25
Join and Win
current value in iso
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
what this iso<current value mean...In hyper mesh tutorial help 'design concept for a structural c_clip' the value given as 0.3..how one can say this number is right value that give optimal material for over all stiffness and max displacement (i;e:required displacement)..
thank you.
1 - 1 of 11
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    The iso value when you are post processing topology optimization results, represents the element density values between 0 and 1. sp when you use the value 0.3 you are specifying display of elements that have density more than 0.3 to 1.0
    Use this tool to get a better look at the material layout and the load paths from OptiStruct.
    This is more of a visualisation tool, the density threshold matters when you are extracting the geometry, say in OSSmooth,
    see image below
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-50648400-1410165745_thumb.jp
