i got the deformation like this.
why its comin like this. i followed the same way as in this link (https://www.youtube.com/watch?v=tvy6aFAtnxc)
Hello Thanga,
Can you check if the SPC load type you have created is SUPORT1 and it is associated to the correct field in Load Step Definition?
I'm attaching here the solved model so you can compare with your model and help to debug it.
Hope it helps. Thank you!
Hello Thanga,
