Impact analysis question!!
Hi
We are doing a car impact analysis against a pole (created as a rigid wall - Geometry type = cylinder).
The simulation is running, but the impact only affects the front part of the car, it does't transmit the impact energy to the entire car. We think that we are missing to make a contact between the entire car, but we don´t know how to do it.
As you can see in the second image, the front part of the frame, goes through the base of the car.
We are using RADIOSS, but we are using Midsurface, so it is 2D elements.
And we are using Shell elements.
Here is a photo of the actual mesh.
We follow the RD-2550-Simplified Car Pole Impact tutorial, to made the pole, ground, load collector of velocity.
Dear Fernando,
You can learn from this video tutorials.
https://www.youtube.com/watch?v=nbJstdvCMTg
https://www.youtube.com/watch?v=gM93KXwhyos
https://www.youtube.com/watch?v=4dB-FvflHm8
https://www.youtube.com/watch?v=TvBBtCCr2Ns
https://www.youtube.com/watch?v=ip3Oej-cHRM
https://www.youtube.com/watch?v=6ZR0fpoFPXU
https://www.youtube.com/watch?v=RWds5U1-4Ag
https://www.youtube.com/watch?v=TkPWTMi8k7Q
https://www.youtube.com/watch?v=f-VSLl_6_Jc
Hi,
Which solver you are using?I hope you are using 1d elements for car.How many 1d elements you have along the length?What element type you are using?
Regards
Rahul R
