🎉Community Raffle - Win $25
Join and Win
Clocking out Signal
User: "Markus_20691"
Altair Community Member
Updated by Markus_20691
Dear Embed support team,
I have a question: I need to clock out data from an ADC therefore I need to be very precise in giving out the right signals at the right time.
I would like to know if Embed can perform or provide any solution or tool to program the correct timing of rising and falling edges of a MCU to give out the signals in the correct order.
I attached a picture of the timing diagramm which I need to program with Altair embed 2021.
Kind regards
Markus
1 - 3 of 31
    User: "pdarnell"
    Altair Employee
    Updated by pdarnell
    Hi Markus, Which lines are you reading and which lines are you writing?
    OP
    Hello Peter,
    thank you for your response.
    CONVST, CS and RD are the lines I am writing and
    BUSY is the line I am reading (and theoretically the parallel Bits (DB0 to DB15)))
    Kind regards
    Markus
    OP
    Is it possible to time these events with a state machine or is there another solution for timing these events?
    Kind regards
    Markus
