Hi,
When I perform steady-state thermal analysis in an assembly it throws an error.After removing 1d beam elements form I got the solution.
Is 1d beam elements will work for thermal analysis? because I need to perform coupled analysis as well
Which Altair product are you using? I will direct your question to the correct forum once I have that information.
optistrcut 2021
