🎉Community Raffle - Win $25
Join and Win
WinProp Tunnels get exported without walls at the ends.
User: "Sam Auffenberg"
Altair Community Member
Updated by Sam Auffenberg
Hello,
i do have the issue thet tunnels that i crates in TuMan are being expoted without walls at the tunnel portals.
Can they automatically be added or is there a easy way to add them in WallMan?
Thanks in advance
1 - 5 of 51
    User: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Sam,
    Have you checked for warnings during export to .idb in TuMan?
    Best, Zeina
    OP
    Hi Sam,
    Best, Zeina
    Hi Zeina,
    There were no warnings during export.
    User: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Sam,
    Can you please share with us the .tub file so that we can  try to reproduce and solve the issue  you are having?
    Thanks,
    Zeina
    OP
    Hi Sam,
    Thanks,
    Zeina
    Yes
    .tub file is attatched in the .zip file
    Thanks,
    Sam
    User: "Zeina"
    Altair Employee
    Updated by Zeina
    Hi Sam,
    Thanks for sharing.
    Please note that generally the tunnel portals are open. TuMan does not define a closed tunnel. Nevertheless, if "Additional Data (Closed) is defined within a cross-section, TuMan creates a vertical wall and both end of the tunnel track. Please check the following explanation section :https://help.altair.com/winprop/topics/winprop/user_guide/wallman_tuman/tuman_usage/tunnel_cross_segment_groups.htmSection 4.5.2 Segment Groups
    Coming back to the model you have shared, there seems to be an intersection violation with "Additional Data 5" and the closed curve of the Tunnel cross-section. It should be removed/modified. For reference, this requirement is mentioned in the same section above under Tunnel Wall.
    I hope this helps.
    Best Regards,
    Zeina
