Woven Material Unit Cell definition does not work
Hello I get this error. Idk what i should do.
Altair HyperMesh v2021.2.0.31 Copyright (C)1990-2021 - Altair Engineering, Inc. All Rights Reserved.Contains trade secrets of Altair Engineering, Inc. Copyright notice does notimply publication. Decompilation or disassembly of this software is strictlyprohibited.
Error: Internal error0 while executing"*solid_extrude_from_surfs 1 0.0 0.36966345402174583 0.02050431940706693 9 2" ("eval" body line 1)
invoked from within"eval *$COM 1 [expr 2*$x*$i_x] [expr 2*$y*$i_y] [expr 2*$i_o] 9 2" (procedure "GeomHelpingHands::createPieceLinWeave" line 53)
invoked from within"GeomHelpingHands::createPieceLinWeave $incs $extrDir $tow_seq" (procedure "UnitCell::Woven::Linear::build_geom" line 56)
invoked from within"UnitCell::Woven::Linear::build_geom $uc_loc" ("3" arm line 1)
invoked from within"switch -glob [UnitCell::get_mid $uc_loc] {"1" {UnitCell::Fibrous::build_geom $uc_loc} "2" {UnitCell::Particulate::build_geom $uc_loc}..." (procedure "UnitCell::build_geom" line 5)
invoked from within"UnitCell::build_geom uc_loc" (procedure "MDS_ParaUC::get_single_femodel" line 26) invoked from within"MDS_ParaUC::get_single_femodel uc" (procedure "MDS_paraModelib::get_uc_models" line 19)
invoked from within"MDS_paraModelib::get_uc_models [ParametricModel::get_paramModels $Model]" ("UnitCell" arm line 7) invoked from within"switch -glob [ParametricModel::get_type $Model] { "UnitCell" { # Build Material Material::build [ParametricModel::get..." (procedure "MDS_paraModelib::main" line 25)
invoked from within"MDS_paraModelib::main "C:/Users/xxxx/Documents/MultiscaleDesigner/test_woven/Mechanical/test_woven_geo.dat"" (file "C:/Users/xxxx/Documents/MultiscaleDesigner/test_woven/Mechanical/driver.tcl" line 2)
invoked from within"source C:/Users/xxxxxx/Documents/MultiscaleDesigner/test_woven/Mechanical/driver.tcl"End of command file - terminating.HM exiting with code 1
Generation of parametric unit cell model finished successfully.
Please save your .mic file and contact Altair support to report the error.
hi,
could you share more details on what were you trying to build here, before the error appeared?
